- Thread starter
- #61
Well I finished painting the axles, and started putting them together. Got the back apart, pulled the axles and the seals were leaking
It's the weekend, so I have to wait till thursday.
Got the front together, put one side together, then went to the other. Got as far as the spindle and realized, like an idiot, when I went through parts, I got the spindles mixed up, and threw out the mini truck spindle, and kept the landcruiser spindle. Won't fit on the mini truck birf
3 Puppies (Paul) is sending me one, so that will wait till thursday also.
SO, I decided to finish the frame. I only had a couple things left- they were replacing the rusted out inner frames in the rear.
They both looked like this, or worse. I started by making a template of the part being cut out. I decided I would cut the groove in the rear, but not the hole
Then I cut the infected parts out. I cleaned up the rust inside, and coated with POR rust encapsulating paint
Welding them in was pretty easy, once the pieces were fitted
All that was left was to grind down the welds. Tomorrow the frame will get a coat of POR rust encapsulating paint, and a top coat of Eastwood Chassis Black
soon!
