Some time ago I started collecting parts to strengthen the axel housings on my 69' FJ40 . I Bought two axel trusses from Bullistic Fabrication , one for the front and and one for the rear axel.I have a traction bar mount allready welded to the center of the housing . I split one of the trusses to fit around the traction bar mount and tig welded it . I also extended breather tube to go through the truss . Now i pulled diff cover off and fab. a ring out of 1/2" plate with the same bolt pattern as the cover ,simmerly to the one Trout Intdustrise sells except I added a wing on each side for mounting purpouses of the diff cover protector.I need to say this is going between the housing and the diff cover. I need to find longer studs to bolt this up. where can i find these studs. thanks Dennis
