Just an idea to check.
How old is the fan bracket/bearing? Mine started making a strange whine that would disappear after the engine had warmed up. I never saw the fan pulley bearing wobble or give any classic symptoms.
The strange belt noise I experienced was from the back of the belt making contact with the fan pulley that would not spin as easily as it should. Once I got into checking other bearings, I did find other bearing issues.
When I first checked pulleys with the belt removed, I couldn't determine the fan pulley bearing status with the fan and clutch attached until the problem progressed to the point where it was noticeable the fan pulley bearing was becoming a problem.
The back of the serpentine belt was dragging against this pulley surface.
