beadlocks that fit an 80
Chesterfield, VA
Ok. just spent 30 minutes searching for beadlocks that fit an 80 in the forum. Not finding the info I want.
What companies make a 16x8 beadlock in black that requires NO modification or spacers and fits properly?(correct backspacing). Name of particular style would be appreciated.
Not sure what your looking for, Hutchinson is about the only street legal beadlock 17x8.5".
Battle born 17x9 4.5" backspace is another options (not street legal).
If you're running beadlocks you're probably running 37s or bigger. There's just no market for 16-in tires in these sizes.
Yep, pretty much no tire sizes available beyond 315 for a 16" wheel, hence why all the beadlocks you're finding are probably 17" wheels.
Method 105's
those look like 105s 17X9 -38mm.
You should look into method bead grip like the 701/703, 16x8 0 offset. No bead lock but there are videos out there of guys running <10psi
We had 106 17x9 -44 on a customer rig for a while with 35s, they worked great. Customer just didn't like the idea of torquing ring bolts as recommended by manufacturer.
if anybody is looking at these for an 80 (the 7xx wheels), the lip in the center bore needs to be knocked down before they will fit over hubs.
