UPDATE - The kit is off the truck, old springs and shackles, shocks all went on without trouble and the driveshaft went right back into its proper place!!!! Time to start saving for another kit like OME that will work.
Dave.
HELP. I guess my first mistake was asking a dealer to do the install, but here is the current scenario: BDS 2.5 lift with 1" greasable shackles and the dealer can't get the spring pin to line up on the axle. BDS Tech Support suggest removing the grease zerk and allowing the driveline to compress. Dealer REMOVES driveline and installs the spring and pin, but still can't get driveline back in place. Dealer installs original shackle and is getting closer to fitting the drive shaft, but thinks they will need to send it out to be cut and balanced? What is going on? Any chance this is a sign of worse things to come?
One positive thing, I told the guy to go easy on her and he said "There is nothing I could do to hurt this rig, she is stout unlike some of the other that bend and brake
Thanks,
Dave.
Dave.
Thanks,
Dave.
