Bad MTR Day in Idaho
North West Cruisers of Idaho did a run of the same trail on both Saturday and Sunday this past weekend. The trail was called Lost Trail mostly because route finding it terribly difficult in a land of monotonous sage brush and desert mountains without GPS coordinates and having run the trail numerous times. The trail is one of the easier trails of the area with a few lava rock ledges, some twisty washes and a few optionals. I had originally planned to go out both days. It as been a while since I have been wheeling and I was eager to test out the truck. Eric Vogt and I made up the Saturday group while the Sunday group was a bit larger with 4-5 vehicles. We got to the first optional challenge and my front elocker was dead so I was unable to climb that one. Already I was starting to see getting home early repairing the locker and making that climb on Sunday. Didn't happen!!!!!!!!! In a twisty wash, my front tire knocked loose some lava rock off the edge. One sharp one punctured my front right. I was attempting to climb out of the wash when my rear took a 2 inch clean slice right through the side wall. We were prepared to winch the truck up to some flat ground change out the tires and get moving. However, my battery slipped sideways in the tray and removed the negative cable from the post. This set off my much hated alarm and disabled the starter. This would not have been a big deal but I left the keys with the remote at home. We loaded into Eric's 80 (2 adults and 3 kids under the age of 6) and headed for my house. We dropped off my kids, got my other keys, grabbed the spare off my 97 80 series, and returned to the scene of the crime. We filled the front with CO2 (thanks Eric) but could not do anything about the rear. It was an easy winch up with a few moments of scary slide will with a flat downhill rear tire, and finally getting to flat ground. We changed out the rear and started on the front when we noticed that Eric's 35" spare would not work with the bigger calipers on the front of my truck. So we get the smallish worn 33" spare from my 97 on a stock rim and fit it to the front. Last problem, we did not have the special lug nuts for the rim so we had to use what we had. The trip home was slow with frequent stops to check that the lug nuts were still tight. The day ended for us both just before midnight. Eric is now skilled at running this trail day or night. I believe that other tires may faired better on the font side wall puncture but the rear tire tear was ginormous. All in all a very good day.
Michael Aaron
91 V8J80 with 3 good tires.
Some shots of Eric on the typical terrain.
How could you forget the kid's favorite part of the day? We took a long lunch and we captured a little lizard. Don't worry he was a participant in the Idaho Catch and Release program for High Desert Wildlife. Also the Uglibus 2 doesn't fit real well through some of the Idaho cattleguards. It has to be something about those crazy offset wheels. That is it, I guess I've exceeded my quota for attachments.
My 5 year old son's photo of the lizard.
You think the BLM will change those cattle gaurds out once they realize we're using them? Or will they make them even smaller? Personally I like them the way they are, just wide enought to squeeze through, skinny enough to deter the Sunday driver.
I was half expecting to see you guys camped in the trail today. Sorry I couldn't help yesterday, I have wheels now and will get the MTR's mounted this week (in case you need a third spare Mike).
Michael,
Good to see you haven't lost the ability to really screw things up on your truck and still have fun! Had to go home to get the remote to reenable your starter??? Sounds just like a Colorado Uglibus story. It's a good thing you are good at making friends. :) Great pics, as usual and say hi to Cooper!.
I think that they will just close those trails. Unfortunately, without a lot of input that is what I see happening. It would be nice if they would just make a gate next to them. I don't mind gates. It is better than trail closures. Also, on this particular one there was a gate, but only horse sized.
I probably should have listened to your advice about tire and the sharp lava rock around here. It is much different than CO. Hard to believe the little rocks in the desert can cause so much damage. Maybe Swampers next time.
Way to sneak a reference to your tires ad!!!!! I will trade you the bead locks and 3 good MTRs for the 38.5s TSL on Trudesigns.
