Hello all. I've been a long time reader here in 80-series tech, but this is officially my first cry for help.
After attempting to chase down a no idle problem (details below), my '94 LC (1FZ-FE) now cranks but won't fire at all. During the bulb check, my CEL doesn't illuminate. So far I've:
- tested my EFI main relay
- checked the 10a gauge fuse, 15a ECU-IG fuse, 7.5a IGN fuse and 10a ECU-B fuse with a multi-meter. All are good.
- Per the FSM, I have back-probed the following terminals at the ECU +B1, BATT, M-REL, STA, B+, and IGSW and all are giving ~12v with the key on.
- Per the FSM, I have followed the flow chart to test the MIL. Grounding pin W of the diagnostic connector DOES cause the MIL to come on, so I know the bulb is not bad.
- The next step in the flow chart was to check pin E1 for ground at the ECU, and there is a good ground at the pin. After this, the flow chart recommends I replace the ECU.
My ECU part number is 89661-60221
Does anyone have any thoughts on where to proceed from here? I don't want to drop the money on another ECU to a.) have it not be the problem or b.) have whatever is actually causing the problem fry the new ECU.
Some background: This all started after removing the TB and upper and lower intake manifolds to replace the EGR VSV, a blown PHH, some vac lines, and the fuel filter.
After reassembling everything, the cruiser wouldn't idle and would stall out when coasting to a stop once it warmed up. When cold, it would idle rough but wouldn't stall. Disconnecting the wiring harness to the IAC valve allowed me to limp around without stalling when the engine was warm. I borrowed a Snapon MODIS scanner from a friend and was about to start running through some diagnostics on the MAF and IAC when the scanner started randomly losing its connection to the ECM. I disconnected the scanner and returned it to my friend, and the truck ran (with IAC disconnected) for two days after using the scanner before I got in it the other day and it just cranked but wouldn't fire up (from cold start). That was when I first noticed the MIL wasn't coming on during the lamp check. I have not attempted to reconnect the scanner (I'd need to borrow it again), but I cannot blink any codes by jumping the terminals in the diag connector.
