Deciphering the 80 series ECU
NoCo
Just a topic for discussion after looking at a few different ECU’s.
I’ve been told that the ECU is the same for 1995 thru 1997 and that they are interchangeable . But, I am finding that they have different part numbers ?
The ECU part # for my 1997 80’s VIN ends in 60652. Another 1997 ECU part # ends in 60651
On a couple of 1996 80’s the part #’s end in 60261 and 60260
All of the part #’s begin with 89661
Why do they have different part numbers if they are interchangeable? Both 1996 and 1997 80’s are virtually the same vehicles in my understanding.
Do the part numbers indicate different production dates or does it mean that the ECU’s are programmed differently?
If anyone can shed some light on this I would appreciate it .
Here's what I've observed about Toyota part number conventions. The first 5 digits indicate the "type" of part, so basically you can expect every Toyota ECU, to start with those five digits. The next 5 digits have different conventions depending on the type, but they often have a "base number" picked for a given model. For the 80 series, that's 60060, so if you put 89661-60060 in for example you'll find it's the original ecu for the FJ80 series models. Where they need different "lines" for model variations, IE, for LHD vs RHD, manual vs auto, engine type, etc, they'll often pick another number with a last digit of 0. The reason the last digits starts at 0 is that by convention, they increment this number for "revisions" of the same part, so if there'd been a revision of the FJ80 ECU, it would have been 89661-60061. These are often (but not always!) backwards compatible revisions.
The parts ending with 6065X are technically for the LX450. To confuse things further, even though they have distinct part numbers, they could technically be identical to the 80 series versions with different part numbers. Toyota do that sometimes, identical parts under different numbers with the different "model codes".
In a nutshell, you can assume some things from part numbers, but there are few guarantees. Where possible, replace with matching part numbers unless you have a way to verify compatibility. With mechanical parts this is often easy. With something as complex as an ECU, there could be differences that affect fuel efficiency or performance, not much way to know.
