B-series & H-series landcruiser Engine-Serial-Number/VIN-Number thread (3 Viewers)
A friend in Sri Lanka has:
BJ43004932
B 0624159
11411-56050
The only original details I have for mine is BJ40013719 as when I got it (18 years ago) it had a 2H fitted as it had been a winch race truck. Tha docs said it was a 77 but an old guy in a Toyota spares department said, "no,it's older than that'. A while back I found the following tables which may well be on here but I can't remember where from but they may help...
More to come
Model: BJ40RV-KO
Frame No: BJ40-051294
Is this 1980 or 1981? Hopefully I'm in the correct place. The reason I ask is I need to replace fuel cap and there are 2 options 80' & 81'.
Thanks in advance.
I also just saw that yours wasn't too far before mine.
1981 BJ40
Chassis: BJ40-051130
Engine No. B-00465614
Hardtop
This is my first post. New member, new BJ40 owner. Thanks for all the valuable resources posted in the forums.
Landcruiser model : BJ40LV-KC
Build date (as accurate as I'm able to determine): Oct 1979
Engine Serial No: 0310392
Block Casting : 11322-56020
Frame No. (also called "VIN No.") : BJ40 - 0041132
Am trying to get the info right on my 1979 Costa Rican BJ40.
VIN is BJ40-029041, B engine serial is 024468 and the aluminum data plate was painted over by the PO. Does anyone have any picture of what the data plate on the firewall should look like for a BJ40? What info is on there? Thanks! (Pictures: what it looked like 1 year ago, plus what it looks like today. Almost finished!)
View attachment 2748725View attachment 2748730View attachment 2748731
That’s not 1979, max. 1978.
Hi Everyone:
My BJ42 was imported from Italy, with a MO title in 7/18, here are the numbers, sold to me on 10/2019 as a 1981:
Model: BJ42KV-KCW
Build date: ? wish I knew! I saw a chart with a range of 8/80 to 9/82 from a website ToyoDIY.com.
Vin: BJ4200901353
Frame: BJ4200901353
3B Engine S/N: 0444506
Block No: 11411-58010
Interesting, I have been searching for information on a BJ42 we have in the shop right now that was imported in from Ukraine, that was originally from Italy. It was Supposedly "rebuilt" in Moldova before being taken to Ukraine.
It appears to be really close to the one you have
VIN/Frame# BJ4200901231
3B Engine S/N 0443324
Shows to be a 2/81 production
Thanks for all this great info guys..
Im trying to work out what year my B engine is so I can order the rebuild kit.
The problem is I bought the engine only from a wrecker to put into my series 3 88inch Land rover so don't have a body serial number. The wrecker told me it was out of dyna.
So going from the block number (11411-56060) it looks like it might be around 1980 ish?? The placement of engine serial number (0899529) between intake port 1 and 2 would suggest it could be a 1984 or 1986??
Im confused???
Any advice on where to get a rebuild kit from??
1977 BJ40
VIN BJ40005997
ENG# B0115546
COLOR Anaranjado (Orange)
Imported from Costa Rica. No roll bar or heater.
Hi, did you find more information about your build year/month?
Mine is very near frome yours, couldn't finde more info.
BJ40 LV-K
Build Date 1977
Frame N° BJ40006760
Engine N° B0119536
Color/Trim 416/LA11
If someone can complete the information or knows where to look at it....would appreciate the info!
Best regards to all from Uruguay!
Fernando.
Have a 3B on the engine stand right now and I show a casting number on the left rear of 11411-58010 and a serial number next to injector 1 of 0470000. This was purchased many years ago and I'm going to start rebuilding it if it isn't warped or cracked. Any ideas on what year this engine might be?
From the broken information and history on this one there may be issues with the precombustion chamber cups.
My running 1979 BJ40 also has a 3B motor swapped in to it but I am not close by to get the serial and casting number off of it. I'll post it as soon as I get back home.
