Juste before my 6.2 Gm swap. I want to have some clues about my B engine.
I rebuild injector, diesel pump and motor. so the complet engine is like new.
When I run on highway, I have high EGT temps 1100F at 100km/h 2200rpm. (often talk about it)
When I put my transmission to neutral on the highway, engine stall
This weekend, Engine overheat on highway and motor grip when it's stall during I change speed from 5 to 4
It's never overheat before on highway and don't overheat or stall at 90km/h.
Engine start after sometime (lower water temp). So engine isn't broke.
The engine start avec 5 sec of glow plug and 1 piston turn.
I ask you some answer because I swap the engine after 1-2 year trying to find why this engine doesn't like me.
I will look all part separatly and all bearing gap. I think my rebuild head have something to do with this! because all the other part doesn't have power to change something with high EGT or overheat. (rad's new)
If you have a starting point to help me I will look at it !
