Looking for more bees to agitate...
Thanks, I do understand the physics involved. I do understand that the net rotation axle shaft to axle shaft is flat. However, it does not equate to equal spin wheel to wheel. It is the rubber on the road that makes the difference.
With a locked CDL and no ABS there is nothing to prevent one wheel locking and forcing the other on the same axle to spin twice as fast, pushed by the other axle, breaking it free.
Example/Scenario:
Going around a corner to the right at 25 mph, braking, right side of road is sheet ice, left side of road is clean pavement. Sheet ice ends suddenly resulting in the front right having traction while the rear still does not. This is a very comon road condition anywhere that the snow is removed from a crowned road by a flat bladed plow.
With ABS:
Right front and rear (both) ABS chatter like mad, braking ability is reduced but controlled. Some traction is retained on the ice side. Rear braking suffers the most. All 4 wheels turn at or near road speed throughout.
CDL on (no ABS):
Right side wheels both lock up when brakes are applied. Left side wheels both turning at same rate, but hopefully holding the line. Linear control (keeping it straight) becomes hard as the vehicle wants to rotate left as the driver is turning it right.
When the front right hits traction, it chirps and starts to turn at road speed. This means you have two front wheels moving at 25mph. The CDL is locked so the rear axle must get a net 25mph*2 spin and it is going to happen suddenly. If the left side has perfect traction, the right will likely spin up. If the left has marginal traction it will possibly spin up beyond road speed... be sure to hold on with your thumbs out at this point because operator involvement has just become optional.
The effect of the CDL is evening up the drive shaft speeds and doing nothing at the wheels during differential side to side traction and weight distribution scenarios. The left and right sides are on open diffs and will still behave as such.
/*sarcasm filter on*/
Clearly we are all idiots. Clearly the Toyota engineers who created the FZJ80 drivetrain were all idiots. None of us know how to drive.
/*sarcasm filter off*/
I can try to explain IBFD better, I can't change physics? It's clear that you disagree that IDBFD is a physical property of a locked center diff. I can't address that part easily, except to understand that maybe I should back up and deal with Ideal Axle Torque Distribution during acceration with a locked diff first.
Example/Scenario:
With ABS:
CDL on (no ABS):
But I have tried the testing in several different situations and so have others here and we've all determined that there is dangerous amounts of binding and windup even though "windup" apparently does not exist (well neither does the perfect turbo, or the perfect suspension or whatever else he suggests is not perfect but has no alternative for either!). Sooner or later he'll shutup and you know when that will be - EXACTLY when everyone stops listening and/or when everyone stops arguing!
(Or has Rick decided he's done with him these days?)
