alia176
I've posted this before but just a quick reminder:
Noise was pronounced on right hand turns over bumpy roads, eminating from the driver side. Possibly from under the floor area but not sure. As of late, this particular noise seems to be more pronounced, even on straight, broken asphalt road. Perhaps something inside the driver door? This is not a squeak or rattle. But, rather a heavy metal on metal sound. More tire air pressures make the noise more pronounced.
The noise does seem to go away/reduced when going through rain, or wheelin in wet conditions.
Here's what I've done so far:
-tighten body bushings
-no loose wheel bearings
-checked front radius arms and rear trailing arm bolts and bushings
-not rear sway bars (still noisy when disconnected)
Anything else to check/tighten?
Thanks fellas.
Thanks fellas.
