are u guys running an aux fuse box?
lx450landcruiser
Moderator
Seattle
Visit site
ok i have 6 lights in front, 2 lights on each side, 2 lights in the rear, a CB radio, a stereo amp ect....... all of which is coming off the battery pos so its getting kinda clustered. i was woundering are all you guys with this many accecorys running aux fuse boxes? or i have seen a clamp that attached to the pos post, its kinda like a metal bar that extends off the pos post and has a bunch of plugs so you can plug in your wires with out the cluster of them all being bunched together. any one see this?
thanks
mike
buggerville nj
Visit site
I run military terminals on the batts, with some juicy thick wire back to 2 remote boxes, 1 under the ps front seat (idea pilfered from Christo) and the other to the rear ds quarter panel. Makes a huge difference. Both boxes have both switched and constant power.
Visit site
http://www.sleeoffroad.com/technical/tz_interior_fusebox.htm
Visit site
I also use two aux fuse blocks.
The first one is behind the aux battery (here, with the box & connections removed) for exterior lights, etc...
The second, also a carbon copy of Christo's installation, under the PS seat for interior accessories, fed by the large gauge maxi-fused cable visible in the first pix...
Cheers, R -
buggerville nj
Visit site
Flatlander - bite your tongue. I'm :ban: from Radio Shack. Seems as though they didn't like the fact I was trying out one of their soldiering irons in their store. ::) :flipoff2: Then again, I hate that place and wouldn't buy anything there unless emergency.
Only top notch stuff. In fact most of my high end cabling is welding cable. :D :D
Golden, CO
Visit site
Very Clean and convienent! I like it. Tell us where you got the stuff so we can copy you:). Where can you get military terminals, and where do we find these aux fuse boxes? Thanks, I've got a 55 I need to wire us some spare boxes into.
Visit site
Tyler cited a source for the interior fuse block - Ben at Slee Offroad also has a source, I believe. The exterior 10-circuit block I used is a Echlin FB6414 fuse block (available from Napa) - one of many in their catelog to choose from, as are others from other national chain auto parts retailers.
A closer look at my under-the-hood setup... the relays control the aux battery charging circuit.
Cheers, R -
Somewhere in the foothills...
Visit site
Ron,
I'm familiar with those sources. A dual battery set up is the next project now that I've finished the onboard air fiasco. I'm open to ideas at this stage. I'm still leaning toward the Hellroaring unit that Yomama installed a few years ago.
-B-
Gumby
Supamod
s-Moderator
Knee deep in hookers and gin
Visit site
In the absence of being able to reply to a PM for some reason, the Sable maxi fuse box came from an early 90s Sable. It is located aft of the left strut tower, near the hood hinge. Coincidentally, this model Sable also tends to have the much coveted two speed electric cooling fan.
