Are pre disk brake rims a different size?
memphis, tn
Is there a size difference between the rims from a FJ with drum brakes and a FJ with disk brakes? I want to sell a set of rims I have but dont know what year FJ they came off of. Is there any difference between the two? Thank you in advance, David
cruiserjunktion
Cruiserjunktion@gmail.com
Supporting Vendor
GOLD Star
North Florida
yes they are different..... some wheels are rivited together (pre 75 drum
wheels) These wont clear discs. The disc brake wheels are not riveted.
Northern New Mexico, Espanola
stinkyfj60 said:
I think they are all 15X5.5in rims and look the same. I sold a set and they had the date stamped on them, check to see if yours do.
I bought them. I mounted some 34X10.5 LTB's. Just need to put the lift on and I am ready to roll.
Vince
jim45r
Bay Area, CA
Has anyone heard of updating the old rims by welding the center to the rim, grinding down the rivets and then welding the rivet bodies to the rim? I only have 2 late rims, and 3 earlies - thought a welding job might do the trick. (I'd have my neighbor, a professsional welder, do it of course). When I was a kid people used to make offset or reverse rims like that all the time.
MOfj40
Brevard, NC
I think that's a pretty common mod. A fully welded rim should be stouter than riveted as well. I'm planning on doing mine as soon as I find a disc front to swap in.
Wherever the truck stops!!
Are you sure that's enough clearance? It seemed when I tried to mount the drum rims over the mini disc conversion I couldn't get the rim on enough before the "step" hit the caliper.
jim45r
Bay Area, CA
I think the 4 runner V6 calipers need a touch of grinding to clear stock rims - check the tech links. On my converted axle with V6 claipers and vented TLC discs, the stock disc brake rim rubs a bit, I just haven't gotten around to marking and grinding (still on blocks).
