Are 1993-'97 80 Series Locked Axle Assemblies Identical?
Crusha
PA
I did a quick MUD search, but no luck. Granted, I only spent about a minute on the search...:p
Anybody know definitively?
Plugging in part number 43110-60400 to toyotapartsdeal.com it says the housing is good for 93 and 97. Not sure how accurate this is since when you select the 93 Land Cruiser it asks if the motor is the "8 cylinder 4.5 liter" or "6 cylinder 4.0 liter." :cautious:
99% positive the housings are the same.
Same goes for the carrier assembly.
I would be surprised if electrical connections did not change however.
I'm also pretty sure they are the same through the range, but not positive.
I'm going to be swapping some axles around, and don't want an "Oh :poop:!" moment...
If the actuator connectors differ, that's easy enough to confirm before install.
