arb air compressor location (1 Viewer)
Bridgeport, Tx
If you have air lockers or an on-board air compressor, where did you put the compressor?
Hello,
Engine bay if there is enough space.
Or below any of the front seats if they are not the suspension type.
Hope this helps.
Juan
It’s dark in Jawga but I’ll shoot you a photo tomorrow.
Not the highest quality photo but here you go. Give Bang a treat.
HZJ77 LHD with HZ1 24v. I thought abought under the passenger side front seat. I don't know if it will fit. There is not much extra space under the hood.
You could probably fit most of the compressor but not all in the rear quarter panel.
I installed mine in the rear panel, don't know if larger models would fit since this is the smallest type compressor and it fit quite snug. I use this only for my lockers, got a seperate portable one I use for inflating tyres.
Is that the right rear?
Yes. I made a small platform which I pop-riveted as shown and welded a leg on the back (if you zoom you can see it) that goes onto one of the bolt of the fuel filler cap hinge, sorta using it as a stud mount if you get what I mean 😄 and secures with a nut which is abit tricky to get on 😏
I can just barely hear mine running in the engine bay but I would be a little concerned with noise in the cab.
