hey just found a deal on 17x9 0 offset wheels for my lx470 i was thinking 295/70/17 wheels along with the AHC sensor lift. does anyone have 0 offset wheels on their rig? if so please post thanks.
well ain’t she a beaut, thank you sir. i guess this shall do since they were only $400, they’ll be replaced down the road as well. nice to hear she was safeThese are 1mm offset, installed prior to my ownership.
They look great just sitting there, but they rub on every part of the fender when stuffed. I suspect someday I'll get different wheels to make it stop.
On a different note, I sideswiped a parked car the other dayand just left tire marks down the side. Didn't touch the body or sliders at all.
Yes everything checked out until i seen the zero 0 offset and thats when i started searching online. Thanks !I'd buy those at $400 for sure. Just verify that the hub diameter is large enough (>110.2mm I think?) so they fit. That's the thing that usually trips us up on wheel options.
Did you paint the bumpers on this? Mine are looking kind of though and am thinking through options.
Can you share more pics please
Hi, no rub on this set up?![]()
17x8.5 zero offset Method 304 with 35x12.50 kenda klever RT
What did you do to stop the rub?
Hey man, car looks great! How did you get the front end to not look like its pointing downwards? Rear looks normal height and front looks slightly lifted maybe? Also, any scrub with that tire wheel combo and if so, how hard is it to fix? I think this is what i'd like to do with my 100 series. Cheers!View attachment 2469443
17x8.5 +0 offset Method 305 with 275/70/17.
Just keep in mind that in Australia, your maximum - legal - offset change is 25mm (ie 50mm track width). So for the hunjy, you can change from +60mm (factory) to +35mm. Not sure about SA, however the Qld scalies are brutal on this stuff.I think this is what i'd like to do with my 100 series. Cheers!
Ahhh good info man. Thanks for that. Last thing I want is attention from the cops. I'll definitely aim to stay within those limits. Thanks for pointing that outJust keep in mind that in Australia, your maximum - legal - offset change is 25mm (ie 50mm track width). So for the hunjy, you can change from +60mm (factory) to +35mm. Not sure about SA, however the Qld scalies are brutal on this stuff.
Here's the NSW blurb, however this applies nationally.
