well, I got myself a NOS M105 coupler ring. Dang that thing is big. 20+lbs of steel.
If that helps some folks later on, below are the various parts numbers depending on the manufacturer. The NSN is of course the same for all. Note that the older superseded NSN number based on the NIIN is still used in various places. Note the various parts numbers (e.g. 7354577 etc), those are cast or stamped on the lunette shank and help with IDing the part and its manufacturer.
The dimensions given by TobiasinLA above appear to match what I have. I have added a pic similar to that of the 101 above to help folks with identification.
Note also that the 1 1/8"x16 nut is an odd thread and somewhat hard to find in OEM form (kindly let me know if you have a good source), but appears to be a standard size for semi trucks wheels if you need one in a pinch (but won't be castellated of course).
http://www.parttarget.com/2540-00-999-5584_2540009995584_2540009995584.html
some of the info in case the link goes dead:
2540-00-999-5584 (2540009995584) NSN Information
NSN FSC NIIN Item Name INC
2540-00-999-5584 2540 009995584 Coupler, Drawbar, Ring 19449
2540-00-999-5584 Manufacturing Part Numbers (SKUs)
2540-00-999-5584 Manufacturer
MFG SKU CAGE Manufacturer Type Status Role
14-503 72865 Copco Trailer Div. Copco Steel And A A
2540009995584 SCY13 E.C.A Etablissement Central DES E A
A-A-52464B 58536 Federal Commercial Item Description A M
296337 23705 Fruehauf Corp. A H
A52464-3 96906 Military Standards A M
MS51339-3 96906 Military Standards A M
11592597 19207 U S Army Tank Automotive Command A A
7354577 19207 U S Army Tank Automotive Command A A
2540-00-999-5584 Replaces the Following Cancelled NSN
Cancelled NSN Cancelled NIIN
2540-00-735-4577 007354577
