I don't get it either. Does your engine run cooler?I don't get it.
If your radiator is boiling off with the stock cap...then you got problems.
I wouldn't want a higher pressure cap to mask those problems, so I drive around thinking everything is OK, until real damage is done.
It will effectively change your power to weight ratio by making your wallet far lighter.
You get that sexy lettering?.. and since (on post #7) "It will effectively change your power to weight ratio by making your wallet far lighter"... might fix that cruiser lean to drivers side.
