^^ This. Mine is the original antenna so it's 20 years old at this point, and was black and grimy and slightly bent on the 2nd to last large one - so it would retract with about 6 inches left and just stop. I tried a bit of WD40 to try to see if it would slide easier, but obviously the bending was binding.Haven't seen any write ups for how to replace the antenna if the cord/ribbon isn't actually broken. I wanted to replace my mast because it was bent, but it was still fully functional. Much easier process, but just to spell it out:
- Remove cap (needle nose pliers work, but be careful)
- Extend mast
- Firmly hold mast in hand
- Retract mast (while still holding it)
- Extend the mast
- Note the direction that the teeth on the cord are pointing. The FSM says they point towards the rear, but mine pointed towards the front.
- Pull cord out. This part it the reason I decided to write this out. The cord will pull out almost all the way with ease, but then it gets difficult. I was hesitant to pull too hard, thinking I may break the cord or motor. I decided to just go for it and pulled with a lot of force. The cord came free, but I was worried I broke something.
- Feed the new cord in. Direct the teeth in the same direction as the previous cord. As mentioned before, FSM says they point toward the rear but mine were towards the front. You will feel resistance after a little bit. Press it in a bit further.
- Retract the mast. If it doesn't pull the new cord in then the teeth are probably pointed the wrong direction. Shift it around and keep trying. I fed them in facing the rear first, even though the old one faced the front. The cord didn't catch so I pointed the teeth toward the front and then it worked. It may not retract all the way at first. Don't worry.
- Reinstall the cap
- Power off the radio to fully retract the antenna. This should pull it in fully.
Anyways, not a hard process but I thought I would spell it to emphasize that force will be required to remove the cord and the teeth may not always point toward the rear.
Following these instructions made it super easy. Another pointer was that once it's fully extended, you can press the "up/down" buttons to retract it if need be. The yanking of the cord out was pretty intense. I was pretty sure I was going to break the cord - then it came off. Fed the new one in manually, then pushed the up/down button with my left hand while holding the antenna in the right hand - ever so slowly. Then the rest was cake.
Thanks for the super easy instructions.
