the dead horse
This is my question exactly from another post on the same issue.
"You could also wire in a fuse, but you would need to know what the fusible link is set to."
https://forum.ih8mud.com/80-series-...sible-link-off-positive-barrery-terminal.html
90982-08264
List: $12.69
cdan's price: $9.52
08-04-09
I don't like the fusible link wires. They look messy, obviously wear out, and don't give much room to play because the way they are attach to the wiring harness is short. They should have wired this into a junction box or something where one could just pull a fuse. Although after reading below...
"the entire purpose for having fusible links vs. just using a fuse is that the fusible link won't burn up when there is a short duration high-amp draw. A fuse would just blow. When there is a consistent high-amp draw then the fusible link gets fried."
"According to FSM & a AWG to Square mm Wire Gauge Conversion Chart-
OEM Main, AM1, & AM2 Fusible Links are 14, 16, & 22 wire gauges respectively"
Glad mine didn't look like this:
https://forum.ih8mud.com/80-series-tech/279630-electrical-issue-smoked-wire.html
I also read that if you do replace a fusible link the wire has to be two sizes larger than the fusible link wire. This is probably why one of my fusible links toasted out because the wire I had used to lenghten the blue fusible link was to small in diameter.
Additional info compiled on the subject for any future reference:
>Fusible links - The advantage is they are materially cost effective. They offer resistance to circuits, which may benefit some circuits with delicate components, such as modules. Fusible links are often used because they can handle power spikes in situations where a fuse or circuit breaker would likely blow. The disadvantage, is that they may need "tedious" work to replace...
I have a big fuse for my stereo amp (in my 60) and an auto-reset circuit breaker for my trailer main power supply (hitch) wiring (in my Tundra and soon in my 80). And I keep the OEM fusible links in place in every vehicle.
Wiring in a CB instead of fusible link would not be hard. E.g., search on Blue Sea DC circuit breakers. Determining the right size(s) would take a little time, and I would suggest a slow burn type of CB. I considered just this when planning a trunk battery relocation on my AMX (I have not accomplished this as yet). I suggest you simply carry a spare fusible link for your 80, as others have suggested. Each wire in the fusible link is calculated to be the correct size to protect those associated circuits. Simple and cheap.
https://forum.ih8mud.com/80-series-tech/542526-wtf-smoke-under-hood-cut-off-traffic-2.html
Nevertheless, my objective tomorrow will to try and get it all back to stock and will have to try and stretch the wire from somewhere down below in order to reach the battery.
I'll also be ordering a couple sets of the now notorious "Fusible Links" from CDAN.
