What's going on with the build Dude? Is it getting rusty or somethin' LOL!!!!
I'm also ditching the stock shifter. I'll need one that can shift 4 froward gears.[/QUOTE
Stock shifter in the Whale is working like a champ I have every notch from the 700R4...
Do we all need one that shifts 4 forward gears? IF OD is by the button then the shifting is D-2-L right? Same as toyo? D=3 and OD button = 4?
Kirk
What year is the Whale? I just bought one from a 92 that has the PRND32L pattern.
Kirk
All I know is what I did to the Whale, it moves the 700R4 just like the GM did.......
I removed the arm from the passenger side of the shifter(inside the truck)
removed the shaft it pivots on, ground the flat down on the drivers side that the shifter you grab sits on, to where the arm would fit here, cut a hole in the floorboard and using the factory rod off the tranny out of the whale I lengthened it about 3" and it works like a champ
Kirk
Kirk you will need to figure out how to wire that into switch. Let us know.But when I run my 4l60 through the gears the pattern is PRND321.
Yeah Looks like the later 80 series shifters wont work. can anyone confirm if a early 80 series has a D321?
Thanks
Kirk
Thanks
Kirk
I bought a 92 shifter assembly today off the parting out section. If you want a stock shifter with PRND32L, look for a 91/92.
I bet have one in the barn from the 91 truck i parted out when I rebodied the shortbus. Thanks
Been reading this thread and doing some thinking. Thanks......I think. Temptation sux!
Just found this thread. Subscribed.
Awesome work! I'm going to have to live vicariously through you until I get the nerve to try the swap myself (or get the nerve to pay someone to do the swap for me).
I love my 80's, but they're in BAD need of V8 power!
Sorry about the shifter issue.
