A little lift, not a little question -
I'm fitting just a little larger tire, 33"; and want to avoid rub so will use torsion bar adjustment for about 1" up front. Questions are:
1. If I'm raising the front an inch; do I need a diff drop? at what increase does the risk for CV leak increase?
2. If you're just raising the front an inch - what do you do with the rear?
I'm changing tires, taking off running boards, getting new rubber, adding gas shocks and calling it good
thanks for the opinions
