keep going, take it apart again or read if this is a typical thing for that engine? valve or valve chain? good luck,
For comparison I ground .006" or .15mm off my head. .5mm (.020") is a lot to grind. That why it jumped out at me.That makes sense, i have the Haynes manual and it states something like "max head shave is 0.400mm".
Last fall they (same shop) only resurfaced the head, it wasn't warped at all. I don't know what or how much it takes off of the surface, but maybe that + 0.5mm this time was too much? I will find out. Didn't have the time to dig in the engine today as i had had few other things to do.
Pretty much the same tomorrow, hopefully monday is quieter.
I agree back brakes are probably fine if the lines were undesturbed, but when was the fluid last flushed?Yea.. on a "normal" car you only bleed front brakes if you only work on them... back to bleeding at some point.
Thanks @dkyuss !
About 3 years ago, IIRC. Fluid was still looking good and fresh.I agree back brakes are probably fine if the lines were undesturbed, but when was the fluid last flushed?
