for some reason the clutch on our '81 Hj47 has packed it in, I didn't have the time to take it apart to see exactly what is broken, so if anyone knows what could have possibly broken I would be grateful.
I wasn't in it at the time, but it was reported to have been driving along normally at 20kph in 2nd 2wheel drive, when the clutch disengaged.
I rolled it out of the shed to check it recently, and after starting the engine, there was an odd clunk every so often, and drive would partially engage then partially disengage independant of foot pedal position. I checked the operation of the hydraulic line and it works without fault. So something inside the clutch has detonated. So before i go out there next time, is there any specifc part that its obvious i'll require?
I can't just pull it down and check it because the property its on is 1000 k from here, and i cant wait till i get there then check because the closest parts are here.
thanks
Sam
thanks
Sam
