I just pulled out the factory amp from beneath my passenger seat and have wired up a new harness according to this website:
I’ve identified all the speaker channels and separated them, and then also bridged the wires it says to under the “Landcruiser notes” section. The picture below is of all those things:
now what’s left are all these cables. I decided to just cut them out of the existing harness since I wasn’t using it anymore and just made sure they weren’t making contact with anything. I had tape covering the wires initially, but I removed that to show you all:
Here’s the issues:
1.) I tried to directly hook up the constant, ground, and accessory power up to my new radio’s harness just to make sure that it will turn on. When I twisted the wires together to make the connection and go to turn on my car, the radio does not start. However, the radio will start from its own power source that is in my house. This makes me think that the B+ in the first picture isn’t actually sending out power or that it’s not grounded.
2.) The digital display with the time/temperature, the recirculate/outside air button, the A/C button, and defrost buttons, and the rear control buttons light won’t come on. All of the buttons themselves function to do what they are meant to, but they don’t have any lights. The little digital display just doesn’t work at all.
Some notes:
-I figure the second issue is caused by me disconnecting the extra wires from the second photo from the harness. That somehow, it knocked out the lights for the HVAC controls. As for what made the constant go out (if that even is the case), I have no clue.
-I cannot find any diagrams online fully showing what every cable underneath this seat goes to. I am completely lost.
-I watched this YouTube video and planned to do what he did: make a new harness and just wire up all the speakers wires, constant, ground, and accessory, feed it into the radio den, and hook that up the the connector your aftermarket radio came with effectively making every other connection underneath that seat irrelevant (or so I thought).
-I left this brown wire with the screw connection intact and still screwed in.
-There is this little bit of wire just protruding from this sleeve. I have no idea what it is or what it does, but that’s what it looked like ( I did not cut off whatever it was going to).
Please, someone with experience help me. This has been an ongoing thing for 6 months and I’ve made no progress. I really just want to use my new radio!
Stereo Wiring: Land Cruiser / LX 470 (1998-02)
Article by: RobRed Applicable Models: 1998 - 2002 / 100 Series Land Cruiser or Lx 470 Changing your head unit to an aftermarket unit is pretty stra
tlcfaq.com
Here’s the issues:
Some notes:
