Alternator “W” terminal? (1 Viewer)
FDo5g
GOLD Star
USA, Central Virginia
greetings and salutations, I just got my hands on a Dakota Digital gauge system and I’m in the process of adding tachometer capability. I can either use an inductive sensor for the tooth flywheel, or the “W” terminal from the 24 V alternator. Does anybody here have any experience doing either of these options on a BJ 40 or BJ 42?
I just added a W terminal to my 2LT LN65. Pulled the alternator, soldered a wire in, and ran it to the Dakota Digital.
Not familiar with B engine pumps, but the ‘w’ wire is a pretty universal solution
Do you mind telling us how you did it?
Sure! You just solder a wire to one of the 3 diodes (have to remove the rear case). Check continuity from the solder joint to the end of the wire. Run the wire to the Dakota digital, and then run that to the tach. The Dakota digital has to then be manually calibrated to output the correct rpm signal.
No point in doing this if your pump has the rpm pickup. Mine didn’t, hence why I went this route.
This is how the W is connected to BJ42’s alternator (yellow wire soldered):
