I kept going back and forth about ordering Denso or something with higher output. The Denso was going to be close to $200 and wasn't going to ship for nearly a week, so I decided to order the 240 Amp unit from phoenix-alternator.com (same company as tucsonalternator.com). These are newly manufactured in Tucson and carry a 2 year warranty.
My total cost $428.99 including the $60 upgraded cable kit, which is required if you want their warranty. They're telling me it's a 1-2 day build time. I'll share the results once I get it installed and run it a little.
I received a new alternator with a pig tail where the factory plug had been. Upon installation I found that this pigtail interfered with the engine mounted gusseted bracked for the power steering pump. Not a big deal - I cut away the interference and installed the alternator (I wasn't about to pull it another time).
I emailed Chris and let them know the snags I hit and suggested the plug be placed on the back of the unit. I'm not sure they took my advice or not.
what's the Voltage booster do? 14.1-14.7 seems normal?I have a nationsstarterandalternator 290A alt and it’s been amazing for years on my 03. Have a voltage booster in and running 14.1-14.7V with odyssey dual batteries
14.1 - 14.7 is normal, most new Toyota/Lexus vehicles are wired with a low voltage system. Factory output is in the high 13V range and will not charge enough to maintain warranty on most AGM batteries. The voltage booster replaces the factory diode, in the fuse box under the hood and boosts voltage back up to keep your charging system in line.what's the Voltage booster do? 14.1-14.7 seems normal?
Got a link to this Voltage Booster?
I haven't heard of it before.
And......it must’ve slipped your mind heh hehLexus - Lexus 4X4 | HKB Electronics
The Alternator Voltage Booster was the first of its type on the market and is the only unit available that was has been purpose built for alternator voltage boosting.www.hkbelect.com
What 120 stuff would buy from Australia?
forum.ih8mud.com
I went withWhich of the ones in the link did y'all go with? It looks like the MK3 might be the one to go with, but wanted to confirm.
I put this one in my cart too...I went with
MK3 Mini blade 7.5A (Electronic fuse version) | HKB Electronics - https://www.hkbelect.com/product/120-mk3-mini-blade-75a-electronic-fuse-version-2007/
said 2-6 weeks for delivery depending on postal code. I assume the 2 weeks is still in Aus. so probably more like 4-6 depending on customs.
Yeah, I ordered 2 (got a buddy with a GX ) and think it was $90 shipped. not cheap, but worth it if it keeps my battery charged and allows them to live a bit longer.I put this one in my cart too...
their listed prices are in Australian dollars, but by the time postage was added, it came to $56 US. ($70 Aus)
is that about what you paid?
