I'm in the process of moving my alternator to the passenger side and I need to extend my wiring. What gauge wire was used originally? It looks like 18 awg. Also, should I just splice in at the original location or is there another way?
Do you have the 84 alternator as listed for the 2F in your sig line?
If it's the original 1971 Fj40 alternator making 36 or 40 amps the B wire needs to be at least 12 ga.
If you've upgraded to the 84 alternator that came with your 84 2F, it can make 60 amps and you should upgrade to 10 or 8.
The other wires don't carry much load, so the sizing is not super critical, and 18 will be fine.
See this: American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies and wire strength
It's not a later alternator with the internal regulator. Since that's the case, it makes 40 amps or less and you will be OK with 12 ga wire.
I have an alternator that should fit better in the bracket than that one if you need it. It's off a 76 and makes 40 amps. It was originally installed on the PS and so the terminals should be in a better position for you. You can have it for shipping. Let me know.
When I put the 85 2F in my FJ40, I used the later alternator to upgrade my available power to 60 amps and upgraded the wire to 10ga.
Thanks for the offer Drew...but do you think I should also upgrade to the later alternator? I have a winch, CB, aux. lights and a marine amp.
More power is always good, and you could get away from the points based voltage regulator, so it would be a win-win.
I don't know what a marine amp is, but the way to look at this is to look at your max amp draw without the winch, ie lights, ignition, stereo cranked, heater blower and wipers on and if you don't exceed 40 amps you should be fine. The aux lights and the stereo though, to me, suggest that more power would be good.
What happens to your charging voltage when everything is on (forget the winch, that runs off the battery only for all practical purposes)? That would be the poor man's way to figure this out. If charging voltage drops below say 13.5 volts at 1500rpm, you need more alternator power.
Is your dash ammeter hooked up and working?
A marine amp is what powers my iPod stereo. My dash ampmeter hops back and forth like a ping pong ball so it's useless.
How hard is the swap to do?
Cruiserdrew said:The swap itself is trivial. It bolts up to your bracket, but you will need some minor wiring changes and an FJ60 alternator plug. If you wire the output B to the (-) side of the ammeter, the ammeter will work like stock. You do need a 12v source for the exciter wire.
Thanks Drew! Any idea where to get an FJ60 alternator plug? Also, which alternator should I get?
Coolerman said:Be aware that if you swap to a higher than 30 amp alternator you will need to swap your current 30 amp, Amp Meter, to the later 50 amp version. If you don't you will fry it the first time you pull more than 30 amps. It's an easy swap.
I would also add a fusible link at this time to protect the B+ wiring in the harness.
The 30 and 50 gauges are not interchangeable.
The 30 is a real AMP gauge. The full current runs through the gauge.
The 50 ('79 and later) is a shunt gauge with a 50:1 ratio. 50 Amps runs through the nest of fusible links and 1 Amp runs through the gauge.
If you replace the 30 for a 50 the 50 is toast when you turn the key because the ignition plus the cluster gauges are pulling a few amps and the 50 can handle only 1.
My advice is to run the stock wiring with extensions to an external 50Amp gauge under the dash.
Rudi
P.s. An AMP gauge is not 12V or 24V it measures AMPS no matter the voltage.
Funny this is TTT. I am in the process of wiring in an FJ60 alternator into a 40 as well. I am going to run a volt meter instead of an amp meter and am going with all aftermarket gauges.
I forgot that I can remove the voltage regulator and have found some posts by Jim C to help me with that. I too am looking for a plug for the FJ60 alternator. I do not have the luxury of any type of auto electrical place nearby. Drew - do you have a brand or part number from the plug? I was thinking I could source it on the web if I can't find someone parting a 60.
