Well I just finished up my LX's front axle service, including switching birfields. I also threw new rotors, 100-series pads and caliper rebuilds into the mix since I needed to service the brakes anyway. Everything went together fine aside from a broken knuckle stud I'll need to replace. Bled the brakes also.
After I put the calipers on and spun the hub by hand, I noticed the passenger side was slightly tighter than the driver side. I didn't think much of it as I expected the 100-series pads to be a tight fit on the new rotors. I took it out for a quick test drive, came back, and the passenger side rotor was smoking hot -- to the point that it actually blued the outboard surface. The inboard surface was fine but saw just a narrow streak of pad contact.
I pulled that caliper and disassembled it again. I made sure all fluid ports and passages were clear, polished up the piston walls, and checked the bores for any problems. Nothing to report there, so I'm stumped.
I'll put the caliper back on tomorrow and test it out. But what else could cause this issue? If these were sliding calipers and the slides seized, I could understand how only one side of the rotor was engaged. But these are rigid calipers and all four pistons moved smoothly in their bores. Some archive reading suggested it could be a brake line issue, but I don't understand that.
I plan to put a dial indicator on the rotor to see if it warped. Assuming it is within OEM specs, could the heat ruin a rotor in other ways?
Thanks folks.
Thanks folks.
