All Geared up and no place to go! (1 Viewer)
Is this the coupling you loosened and let open up/separate?
Bingo! That's the one. After adjusting, there was very little (can't remember now since it's been over a year) "new" shaft exposed after loosening the coupling, I'm thinking, maybe less than an 1/8"? As a mechanical engineer, I truly understand your concerns and I too would have felt uncomfortable to the point of going in a different direction if I deemed it to be unsafe (say, more than 25% of the couplers length).
If you're interested, there's a solenoid on top of the ignition shaft that controls this. Easily to disconnect if you want. Only downside is you risk walking away from your truck not in park.
I may have to look into that! I've already had a valet trash an ignition key trying to get it out of the ignition without it completely being in Park. Luckily, it was only the $5.00 key housing, so it was an easy fix. But I still have to remember to tell every valet to be sure it's all the way in Park before removing the key.
It's the white square in the center.
Been there done this. Disabled mine and one day forgot to put it in park...truck ended up in intersection. Yah. Don't do that.
Ha! Yes, it's there for a reason. I'm pretty anal about my shutdown sequence: shift to N, parking on, foot off, weight transfer to drums, shift to P. This puts zero load on the pawl. And if it ever 'pops' when I get back in I know that I have a parking break problem (which never happens). It is a PITA to adjust the parking break with wheel spacers.
As a side note, I was on the trail a couple of years ago and got out to take a picture of my truck with Mt. Adams in the background. I couldn't figure out why the mountain was moving across my frame... got out with the truck still in D and parking break on. Not my brightest trail moment.
What do you mean by "facing the ends of the blocks"? If it was supposed to be 2", did you shave .25" off each puck? And if so, why?
Any pics? I'm curious to see a few things. Your shroud, the blocks, steering linkage, heater core lines, gaps......
Not meaning to be a jerk, but I don't have the time right now to go through looking for the stuff in my garage to take pictures (read the first part of my original post regarding time). If you note the times of these posts, I'm sneaking them in while I'm at the office. ;)
Regarding the pucks, I believe I made them from Static-Dissipative UHMW Polyethylene (super impact resistant, which is what you want) which can be found on Mc Master-Carr for about $17.00/foot for a 2" round rod. You will only need one foot. I purchased all my long bolts and aircraft locking nuts (nuts with the nylon insert, highly suggested) from Mc Master-Carr also.
When I was referring to facing off the blocks I should have said "pucks". I used my vertical/horizontal electric drop band saw to cut the pucks. It did a fine job, but I probably should have not cut right at the 2" line. As the saw was cutting through, the blade wandered a wee bit and made them all under 2". I then had to chuck them all in a lath and face the ends to make them square. After all was said and done, they turned out to be 1.75" which, again, as it turned out was the perfect amount of lift I needed! :clap:
picks of the truck, the truck... I wanna see the 35s and the overall stance.
thanks!
I just wanna see pics. Tons of pics. I don't care what they are.... ;-)
