Finally starting on rebuilding the Aisin carb on my 87 FJ60 with 2F. I've got the factory manual, a rebuild kit from Jim C. I've disassembled the carb, placing the parts in three boxes to keep track of them (air horn, fuel body, and flange). BUT, I've got three questions.
1. I don't have the SSTs, so I managed to muck up the needle valve seat right where the SST fits in it to remove it. My screwdriver was a pretty good fit, but some of the brass just popped off. The thing is really IN THERE. I tried a little PB Blaster, I tried heating it, still didn't move, and a little more of the brass broke off. I don't think it's ever coming out, so I plan on just dipping carb with the needle valve seat still in place--any problem with that?
2. The gaskets between the small venturi and the fuel body are like they are glued in place. I don't want to gouge the fuel body trying to scrape these off--will they come off in the dip?
3. I haven't drilled out the metal plug for the idle mixture screw--I assume I should do that and remove the screw before dipping the carb?
I'm thinking of dipping the parts in two batches (flange/body parts and then air horn parts) so that I don't get too confused with all the little pieces, and so I can reassemble the body/flange while the airhorn sits in the dip. I assume ALL metal parts can be dipped.
Anyway, this is my "after hours" project and will take a few days, so I'll probably be posting a few other questions.
Thanks in advance. And yes, I am searching and reading--I just hadn't found anything about the needle valve seat, so I posted.
