Airing Up (2 Viewers)
Apple Valley, Minnesota
Just wondering what folks are using to air up tires after airing down for the trail. For my FJ40, I use a Lasfit 12V portable air compressor. The power cables clamp to the battery. We just purchased a 2025 Land Cruiser. The battery is in the back. The minus terminal is easily accessible but the positive terminal is not. There is a rather large red plastic cover the positive terminal making it inaccessible.
I want to be ready when I hit the trails with the LC250.
I’ve got a Thors Lighting compressor in a travel case that I bounce between vehicles. It also needs to clamp to battery terminals. So far with the 250 I’ve always had the trailer wil me so I’ve used the battery in that to power it. Need to wire in an Anderson connector to the 250’s battery.
But if you don’t already own a compressor just get a 120ac unit and plug it into the inverter.
Arb HO single that came premounted in a tool box. Plan on upgrading to a dual arb brushless at some point. Takes a good amount of time with my 34s. I can air up 3 trucks in a row before doing a cool down, in a pinch.
IMO there are two reliable options for airing-up - a high-quality cordless compressor (like a Milwaukee M18) or a ARB compressor (single or twin). There are lower-cost Chinese compressors that are sold as single-head or dual-head units under many different brand names (Smittybilt, Ironman, Thor, Harbor Freight/Maddox, NAPA Maxi-Trac, MORRflate) and they are frankly junk. I had a Smittybilt version of this compressor on my rig hard mounted. I went through two of them before ditching it for a ARB twin. What finally killed the second one was a short in the trigger wire going into the electric motor - the wires inside the compressor are un-sheathed, rub on each other all of the time, and have poor-quality terminals on them. IMO those compressors are a fire risk. Also, the cylinder on mine was pretty badly scored with <10 hours of total use on it, and it could only air up 7 tires before a thermal shut-off was triggered.
A Milwaukee M18 compressor will be just as fast as a ARB single, and about half as fast as a ARB twin. It will be a little slower than one of the Chinese junk compressors but will be much more reliable and portable for other uses. But, if you are wheeling and inflating often, a hard-mounted ARB twin is the best way to go as it's fast and reliable.
Almost everyone in my group used thors lighting twin compressors. None of them seem that old and they have a lower duty rating than ARB.
Viair makes a really great product. They are optimized around air suspension and not tires. So I dont think they are the best option, but still a quality product.
I have the Milwaukee M18 tire inflator with Lock-n-flate air chuck that I carry when on trails. Works very well. The 5AH battery is good for 5 - 6 tires from 18PSI back to 35PSI in ~ 5 minutes total (all 4). I do carry the spare 5AH battery and am sure both are charged up fully before departing.
Major con, if a trip has more than 2 air downs I have to bring along the charger or mooch air. I’ll be looking at the sales for the 8Ah M18 battery.
I have a small cordless one stashed in the truck if I need to just top off a tire.
The OEM onboard air system in the GX OT has been a great surprise the 2 times I've aired down (have less than 3k miles on it) Was skeptical, but I love it.
I didn't realize the Lasfit compressor appears to be one of the Chinese dual heads. If you have this one, it has a max draw of 90 amps - yikes. You'll need to be very careful even semi-hardwiring that to your rig with an Anderson connector to operate it safely. I would use no smaller than 4 ga wire, with a 100 amp circuit breaker very close to where your cables tie into the rig's battery. Otherwise, smaller than 4 ga wiring might get very hot, and there would not be a device to automatically disconnect the circuit during an overload or short-circuit condition.
If that compressor has anything smaller than 4 ga wire leads on it, I'd get rid of it ASAP and get something that is safer to use. They don't seem to call out the wire size specs, but they sure look smaller than 4 ga in the photos. FWIW, I have 6-ga wire running to my ARB twin, which only has a maximum amp draw of 70 amps.
Just use your existing compressor. Splice the power cable for Anderson 120A quick connects so you can use either Anderson or clamps. Install quick connect mounting panel in suitable location in the trunk, near battery on the 250.
(I use Anderson brand, these are generic)
This is how I would do it. Looks like a some other folks have done this. It would be nice if Toyota had provided a direct battery terminal post to each pole under the hood. Battery location isn't ideal for things like winches, snow plows, etc. But not insurmountable. I have a Smittybilt that's been my go-to for around 10 years at this point. Only issue it's had is the hose sucks, so I replaced with a high quality 30 foot hose.
On my older cruiser, (not a 250) for years I used a dinky 12v tire inflator - and it sucked.Too slow.
20 years later I decided to go whole hog and retrofitted my AC compressor to be an air compressor instead - since I never used the AC.
Unsurprisingly, the AC compressor inflated a tire so fast, that there was literally no waiting around.
Having a very powerful air compressor literally changes your off road trips in a very meaningful and great way. Airing up is super fast so there's no hesitation airing down for even small sketchy sections.
Now I'm not suggesting to hack into a new 250 AC system to convert it to an air compressor... but what I'm fully endorsing is to purchase the most powerful 12V air compressor you can fit and afford. I guarantee you won't regret it.
I will hard mount the arb double when I get it under the hood and then plumb a line to each wheel.
I have a LOT of compressors but my favorite is the Oasis HP1000. It's a beast.... it's a winch motor hooked up to a Sanden AC compressor.. and it's quiet. On my 24V LC, it'll blow 16CFM at 100psi!
I hate to continue to be an electrical naysayer, but for a hookup like that it would be good to have some extra sheathing on at least the positive wire. After all, it's buried behind a plastic panel and will be subjected to tens of thousand of miles of rubbing. Having a 6-ga cable direct to the battery shorting out on a sharp body panel edge is not a good outcome - even if a circuit breaker is installed (though, kudos to the installer for at least using large-gauge wire).
Here is how I did a pair of 10 ga Anderson connectors to power my camper fridge off the alternator of my GX. This uses a Anderson environmental boot over the connector, and the wires are double-insulated all of the way to and overlapping each boot with heat shrink tubing. These wires are under my rig and exposed on the camper tongue, where there is a lot of rubbing and potential for water-related issues. Inside the interior of the a rig, braided or corrugated sheathing would do fine, although I'd still recommend the environmental boot or another type of enclosure to reduce the potential of accidently shorting the connector (which does appear to be in use on that photo).
Here is how I did a pair of 10 ga Andersons to power my camper fridge off the alternator of my GX. The hot and ground wires have their factory insulation plus a second layer of sheathing (heat shrink tubing here) from the bus bar I have them hooked to all the way to a weatherproof cover that slides over the connector body.
Or, one can use braided or corrugated sheathing - both of which I have used in other applications on my rig.
I have no idea what's behind that panel. Just a picture I found on the google machine. I'd sure hope they at least have a fuse or breaker on it. On my own junk - I'd use one of these type of flush mount receptacles with a door so it's nice and tidy.
It's only 18" of cable. Flush mounted connector and zip tied cable is all you need.
Length doesn't have much to do with it, outside of the wire gauge selection. If you look under the hood of your Toyota, you'll notice that every single cable and wire is wrapped in secondary sheathing (outside of a few of the ground wires). Even the short ones (i.e., low voltage pigtails from the engine harness to the fuel injectors). Everything is also on a fused connection. A $38 circuit breaker and $3.50 in corrugated cable sheathing would make that a drastically safer connection and lower the risk of burning down the rig.
As an IBEW member I have to agree. Everything must be protected with a fuse otherwise you are literally playing with fire.
It doesn't have to be fancy, but its really unsafe to not use a fuse, considering its still electric theory and occasionally does stuff we cant explain.
There's already a fusible link with an extra terminal for you. Mount the Anderson Connector on the access door or any of the plastic trim. This is a temporary connection. When you use your compressor with battery clamps, are you adding a fuse right at the clamp?
I do normally sheath all my wiring because I have so much of it in both braided and split loom but this is literally a battery on the other side of a plastic panel.
