Hi everyone I've recently decided to get my aircon sorted after 7 years of bearing the western Australia summers. I replaced Evap,dryer,compressor etc etc all new o rings and she has been re gassed and is holding fine. Now my issue has started when I went to press to AC on switch. No power is going to the AC clutch I checked the AC clutch was working by bridging 12v directly to it and she pumped ice cold air so the system is working fine.
But I have a electrical issue somewhere I've tested the AC cut off relay that's fine, I've then checked the negative switched AC coolant switch and that seems to work aswel, I've then found 12v in on the AC pressure switch and bridged it to try get my AC amp to switch on. Now this is where I'm having issues there is no power coming in to the AC amplifier nor is there power going to the relay above it. I've tried running a 12v cable directly to the ac amp with no change.
What could be causing this ? Also looking at my FSM wiring diagram im only meant to have 2 wires on my AC pressure switch but on my 80 I have 4.
Any help would be great.
