Hi all, working with the 60 emissions that haven't been passing since September:whoops:, and the problem is in the CO levels. HC and NOx are fine, but the CO deviation is just too big at low rpms, and it increases as the rpms raise. from what i understand in the fsm (the good one), the air injection system and the oxidation catalyst are to blame. converter tested and is good, although not oem and doesn't receive the thermal sensor (what i have read, that wouldn't help anyway). I've replaced the check valve to the converter with oem, replaced abv and asv valves with used oem, and replaced air pump with used oem. almost all the AI tests from the fsm are passing, but it feels like the pressure from the pump is way too little...like one of those little air mattress pumps. the manual never mentioned a specific pressure, just that it should be in the "green zone" of the SST.
long story short, is my discharge pressure normal from your experiences or should it be pumping out air like crazy?
