Any suggestions for determining the correct size (or a link to a part number) for replacing a missing belt for a 1978 FJ40 air injection pump. SOR's is out of stock/discontinued.
Thank youYou can walk into your local NAPA, parts store, and they will hand you the correct belt. Or, call Kurt at @cruiseroutfit if you prefer OEM. OEM is better, but the Gates belts will work for a lesser amount of time.
What's your thinking? My FJ is running, has been since acquired, without the belt on the pump but seems a bit too much gas fumes. Thought replacing the belt could help with that.Hi, Get rid of pump. Mike
Kurt is a great tip. Unfortunately, he tells me OEM is no longer available.You can walk into your local NAPA, parts store, and they will hand you the correct belt. Or, call Kurt at @cruiseroutfit if you prefer OEM. OEM is better, but the Gates belts will work for a lesser amount of time.
Appreciate you sharing this. The FJ is out of reach for a short while as I am traveling. No way to send a pic right now. Thank you for the suggestions.To add, without the belt on the pump the main smog equipment isn't in service. You can remove it all if wanted or keep if it's running good.
Pics of engine?
May have inadvertently misspoke in my description. Meant a bit too much "exhaust" fume is why I want try to get the pump working and see if that mitigates the issue.If it’s raw gas fumes fumes you likely have something wrong with your tank vent system like @bhsdriller says. Trace out your fuel lines from the tank to the carb. If it’s a rich running smell I would go through the FSM tuning procedures. The AI system is pretty much isolated from either of those areas so I can’t see how a disconnected air pump belt would cause a gas smell.
