Not ready to install a built-in air compressor on the Cruiser. What do you all take with you on treks to inflate your tires? Something reliable, powerful, but doesn't take up your precious space? Thanks in advance for your insights as always.
Is the only difference between something like a VIAIR 450 and a lower end model like a VIAIR 88P just how much time it takes to fill up the tire? Are there other considerations?I have a VIAIR 450P-RV. I use it for multiple applications, but it can pump up 6 Class "A" RV tires to 90PSI, so I'm confident it can handle any tire you'd want to put on a Land Cruiser. It comes in a little tote-bag and has worked well for years.
2x for the Puma they work greatReliable, check.
Powerful, check.
Doesnt' take up space? Errrm....
PUMA, it's been the reliable MUD go-to for the 80 section for well over a decade. Mine has been in service for ~7 years. 100% duty cycle. Will take my 315/75r16's from 18psi to 34psi in a little under 2 minutes a popGood value as you can find them under $350 if you look. I think I got mine for about $250, but everything costs more now.
Now that the 80 is gone, I'm thinking of divorcing the compressor from the tank and mounting it under the hood behind the passenger headlight.
Same here, I go from 18psi back to 40 ish for all 4 tires and have never had it shut down on me.I’m using a Viair 400p Automatic. Nice to have something portable to move from car to car. Yes it’s got a 33% duty cycle but that rating is also assuming 100psi. Since I’m only really using it up to around 40psi I figure it can go a little longer but it’s never taking me more than 20 minutes to air up anyways.
