Hello folks,
I’m brand new to FJ40 ownership and need some assistance telling me the air intake system functions on my vehicle. Here are the pertinents: 1976 FJ40 see attached photos. There is a spring loaded butterfly valve midway Between the air intake horn and the air cleaner. It appears that it allowed either exhaust heated air or fresh air from entering th air cleaner assembly. There is no hardware or cable attached to the actuating lever, so it is closed under spring pressure, drawing from the heated air side. That heated air hose is not connected so it is essentially drawing fresh air but my OCD will not allo me to just leave it. I want it to work correctly and draw air from the air horn attached near the grill.
I’ve done a lot of looking online at pictures and diagrams but I do not see this particular set up. For this style of air cleaner I have seen some that have some sort of a vacuum actuated system that would regulate between warm or fresh air. Can someone tell me how this system worked as in my case where it is a manual functioning butterfly valve?
Thanks in advance!
Obligatory vehicle shot!
Thanks in advance!
