Sounds like 14 grads it is... and I'm far from that.
Looking at the system diagram, I'm still not excluding the accumulator.
The pump is only connected to the accumulator. When the height is changed, the height control valve assembly opens and lets the accumulator pressure start raising the car (front and back at once). The pump helps after the accumulator is emptied (one end at a time, back and forth) See my sped up video going from L to H.
Once the car is raised the pump continues to pressurize the accumulator for next time, while the height valve is closed allowing us to look at pressures at multiple sides of the valve.
IF the accumulator has leaked and there is either less nitrogen behind piston or fluid on the back side of the piston, then the pump still will pressurize and the car will lift but the delta in fluid in the accumulator, hence the reservoir, will no longer be dramatic.
Not saying this is what is happening in my case, but just that a failed accumulator can lead to a smaller delta in fluid level between H and L. What is more reliable, a piston or a diaphragm? One thing I do know is that the globes get ALL the stresses from bumps and accumulator gets NONE, hence the diaphragm in the globes wear out tons more often than the accumulator piston. Long story short, I probably need to change the globes.
I saw someone cut open the globes... anybody seen a cut open accumulator?
Hi TexFJ,
You are right to consider the effects of the Height Control Accumulator and yes, the explanation in my previous post does assume that the Height Control Accumulator is operating correctly. My previous post really only describes some effects relating to new and worn ‘globes’.
So what happens if the Height Control Accumulator is not operating correctly?
You have put forward some ideas and uHu has replied very succinctly.
For me, the great benefit of this forum is that I get to learn from others. So I have laid out in detail my thinking and welcome review and correction from anyone, any where.
It seems useful to visualise and work through the whole AHC system by looking at the hydraulic circuit diagrams as shown in the last 4 pages of the attachment which describes the operation of the AHC and TEMS systems. These diagrams on the last pages show various operations with components in good condition. By the way, some cross-section diagrams of components also appear in this attachment. As requested, a cutaway picture of a 'globe' also is attached
Then it seems worthwhile to think about what happens in various fault or ‘worn out’ conditions.
To be of any use, the “HI/LO Test” must be carried out after the Height Control Accumulator and the AHC pump have completed their operations and are at rest. The FSM (see link to FSM offered in my previous post) suggests that the “HI/LO Test” be done at least 30 seconds after the “HI” indicator light has stopped flashing after an upwards movement. For my 2006 vehicle, I am suspicious about various parts of my AHC system because my vehicle raises and drops very slowly. So I try to make sure that the AHC pump has stopped and usually allow a minute or two just to be sure. The vehicle must be on a level surface. It also seems best that the vehicle be sitting at the recommended heights at each corner so that the pistons in the ‘shock absorbers’ are in the standard position at each AHC setting, “LO”, “N” and “HI”, and so that the pistons are sweeping the volume of fluid expected by the Toyota persons who designed the test as described in the FSM.
The “HI/LO Test” simply measures displacement of the hydraulic fluid from parts of the system under various conditions.
There are only three kinds of places from which fluid can be ‘displaced’ and move in any direction under pressure. These are
- the four ‘Shock Absorbers’,
- the four ‘globes’ (called ‘Gas Chambers’ in the FSM),
- the ‘Height Control Accumulator’,
Thinking about these one by one ….
The ‘Shock Absorbers” ….
The
‘Shock Absorbers’ are simple hydraulic struts which themselves contain no gas pressurisation. The piston inside each strut moves and the vehicle is raised or lowered according to the hydraulic pressure applied to them from other parts of the system and acting against the share of the weight of the vehicle carried by the AHC system.
Complete failure of the struts is rare although slow leakage or ‘weeping’ from struts sometimes is observed – meaning that the internal seals are leaking. This is seen on some older vehicles, or in vehicles where no steps have been taken to correct excessive hydraulic pressures which are substantially above the correct neutral pressures in the front or rear parts of system. These may be caused by long term or permanent heavy loads.
This happened to me! After fitting a heavy steel ARB Deluxe Bar (as seen in my avatar) I did not get around to sorting out the AHC pressures for almost two years. Eventually, the AHC pressures were corrected (using front torsion bar adjustment and new King KTRS-79 rear springs) and the front ‘shock absorbers’ were replaced. The original ‘shock absorbers’ were visibly damp but not dropping fluid and probably could have been left in place. I adopted a conservative approach to ensure reliability in a vehicle that travels long-distance through remote parts of Australia.
The ‘Globes’ ….
Effects from the four
‘globes’ (called ‘Gas Chambers’ in the FSM), were described in my previous post and in multiple IH8MUD posts by others.
If the diaphragm (meaning the resin membrane inside the ‘globe’) has failed and allowed gas pressure to escape, then there is nothing to drive or displace fluid from the ‘globes’.
Eventually, in the extreme case when ALL gas pressure is lost, fluid does not move out of the ‘globes’.
As the ‘globes’ slowly become ‘worn out’ over time (meaning that the gas pressure is slowly being lost over time), progressively there is less and less movement of the fluid from the ‘globes’ to the AHC tank when the “HI/LO Test” is conducted over the years. So fewer graduations at the AHC tank are seen in the “HI/LO Test” as time goes by.
This is why this test is used as a rough indicator of the condition of the four globes taken together. It does not distinguish the effects at any one ‘globe’ on its own. (The ’16 step test’ may give an indication of what is happening at each corner of the vehicle but differences could arise from many causes).
It is noteworthy that measuring AHC pressures – by electronic means including Techstream or by hydraulic gauge – cannot tell us anything about the condition of the ‘globes’.
The ‘Height Control Accumulator’ ….
If the
‘Height Control Accumulator’ has lost pressure or the piston is stuck, then the effect will be similar to a failed ‘globe’. In this situation, the Height Control Accumulator is then simply an inactive container in the AHC system. The hydraulic pressure and volume will be the pressure and volume provided by the AHC pump.
In the condition of a stuck piston or no gas pressure, there is nothing to drive fluid out of the Height Control Accumulator.
There would be no change in the volume of fluid in the Height Control Accumulator.
There would be no displacement of fluid from the Height Control Accumulator back to the AHC tank.
The changes in the fluid level at the AHC tank may then be less than they would be when the Height Control Accumulator is operating correctly.
The time to raise the vehicle from “LO” to “HI” would then be very long compare to FSM specification shown on the first page of the first attachment.
This is to be expected because in this condition of an inactive Height Control Accumulator, raising of the vehicle is driven only by the AHC Pump with no assistance from the Height Control Accumulator, so raising the vehicle will take much longer. It is likely that there also would be several Diagnostic Trouble Codes (DTC’s) occurring at that time --
see link from uHu with attached Technical Service Bulletin – but that is part of another different topic related to the AHC Pump.
Conclusion ….
Once the ‘Height Control Accumulator’ has stabilised and the AHC Pump has completed its cycle and the “HI/LO Test” is performed correctly, the test will indicate the condition of the ‘globes’. The ‘Height Control Accumulator’ will have no bearing on the “HI/LO Test” changes at the AHC tank,
unless ‘Height Control Accumulator’ has a fault which causes it to perform erratically and inconsistently – for example, if it sometimes operates correctly and sometimes does not operate correctly. Repeated “HI/LO Tests” at the same time and in the same conditions and which showed variability in the changes in levels in the AHC tank may lead to suspicions about the condition of the ‘Height Control Accumulator’.
Comments, different views, different experiences, guidance, correction are all most welcome.
Late edit: I should add that I have no idea why the FSM sets a different threshold in the “HI/LO Test” for the replacement of ‘globes’ at 8 graduations in Australia versus 7 graduations for rest of the world. I have not found a Toyota Dealer nor Lexus dealer in Australia that can answer the question. Could it be that there are slightly different versions of the AHC/TEMS ECU firmware – and if so, why so? What about the LC100/LX470 versions sold in the much larger markets in Europe, Middle East, India, Russia, Africa, South America, etc, etc? Nobody seems to know and I doubt that it is worth worrying about too much. When approaching 7 or 8 graduations the ride quality is deteriorating and it is time to think about ‘globe’ replacement. AHC/TEMS is very rare on Toyota LC100 in Australia and was Iimited to top of line ‘Sahara’ (VX) versions from late 2005 until arrival of LC200. Lexus LX470 in Australia featured AHC/TEMS from the same time as the rest of the world (1999??) but the LX470 was considered a luxury vehicle and the numbers of LX470 in Australia are small. Many Australians who live, work or travel frequently in outback Australia prefer a Landcruiser with a conventional suspension, probably upgraded and possibly with a ‘lift’. The land area of Australia is about 11.5 times the size Texas but occupied by only 25 million people (less than the population of Texas) – so there is a lot of road between people and some roads are a little rough. Maybe Toyota thinks that we treat their vehicles a little more roughly than other people and that their vehicles need more protection or earlier maintenance!!
