Aftermarket Wheel Thread (non Toyota, non TRD) (3 Viewers)
Alphaequipt Echo in bronze
17” 8.5 wide +35mm
Kenda Klever 35x10.5r17
Flush with fender.
Super late getting this post up- had em for 4 months already.
The McGuard lugs won’t work. Need extended thread conical lugs.
Here are the alphaequipt command 17x8.5 in the +15 offset. They’re just proud of the fender. The grey is on close out on tire rack for $158 right now. I went lower offset to get the tire out of the swaybar on the RF corner, but did have to massage the front mud flap with a heat gun running 285/70/17 KO2s. A +25 offset would probably be a happy medium, if it were available. Other than the front mudflap I’ve had no rubbing at full stuff front or rear.
Ok, you sold me. was looking to move to a 17 and saw the tire rack deals happening right now. Was nervous about the +15 offset, but seeing you and doing some calculations using the offset calculator, it seems like I am going to be about the same as I am now (or where most are with a RW with a 1.25 spacer).
UI3LvWHPdnlfNq2LZi3q01MF3VX1mPk_5V9lJidYLTaaLrwEl_WSynmbRqNA9RbkqO9aj5amJhNe5uMr4aMBO-ekipQoZO_Gp6z_Yf_hvkss7UIZ1fTU4Wkv2IDxm8D1B-4c1Wd5yO8yN0CMaojYIhY2iVJ_LsNNxuffKbeiHP3Rc7__E99TIWdnfXN4dLdWUPKcH5kzsMvXTVcEQkV8PZK-ov18sJPif6ahdfHsUXUOqiZ_ZgeM2gjM7TS2R-FA91w6ThndB2XrqbGznukRSj8WWxyMVPiFLd6LPxlrdNic9xtxciQX4A8xfbUJBqOLeWnzWryD4vI0xZQ9q9Hilq-0e_we595tEQCPfgQiRAospt7gu7_VCJhPFXBGX3FpRLvxfpqgMk6zQSQDkobWmw-H61ywSYdKWCUp-WK5-8rNdz9_m7VUpmjcUccnFVuLGTk5E6a1tsyDvZKS1n_N8iheV5NLowJj70SWGW3IeGhe13usWPGNUaPFZUbw7ArXE74P36Ucrv9VZbyX-kuuxKatEAS8XCpW2pwY-x0dkzFzjR3FinQQIzd_ww2jtM_yMMVN0TI4nuwWNHI87mPg5vNCEL2cT9d_QrROdo7CNp80TuKTNnDK4t1J5WlRqwGqtVcCz2A5Ar12kAbH3W9uNyxYuscN3HGZoZMQCgmHdG9XH574i9DgYS4U9_YnsqSUOP0ZLxNLZOmUHhHls31YLtEBmNOAYO_Jk29jUy9V-iHSg7mLhVVw8NvjzYBGzyA=w1920-h865-no
