Aftermarket Steering wheel & Hub? (4 Viewers)
Bay Area, CA
Has anyone installed an aftermarket steering wheel and hub on a 100 series?
I got this Boss hub for Lexus to retain cruise control and install a well matched Momo wheel to replace my cracked OE wheel. For some reason with the aftermarket hub/wheel installed my ABS/VSC goes insane and ABS starts locking up as I drive. Reinstall the factory wheel and everything goes back to normal. I even had my local Toyota shop attempt the install while they were swapping out my motor and he had the same issue and was quite dumbfounded as to what would be causing it, he figured it has something to do with some type of signal the ECU wants to see from the cruise control module. I thought I may had damaged the clock spring when initially installing but that doesn't make much sense if it's perfectly fine with the OE wheel installed.
Any ideas?
This is a link to the aftermarket hub (unfortunately the instructions are in Japanese):
Attached is a photo of the wheel for reference.
