Builds after KOH LV build (1 Viewer)
More parts, more paint
That's one way to secure the rear hatch.
Went to the desert last night for some R & R. Cruised down to the creek this morning to see the flow. Spring is great here in AZ.
Wow. That looks great. Is that sprayed in, brushed, or rolled? Who makes it?
It's sprayed in. Pretty sure it's made by Lizard Skin. There's a sound deadening layer and a separate heat layer. Stuff is awesome to work with. Dries fast, no fumes, and cleans up with water. I had good results in the wagon so I figured use the leftovers on the 40.
I do plan to top coat it with the tan paint like the rest of the build.
While changing the diff juice, I swapped in Marlins fancy pinion seals, new pinion nuts and some new drain plugs. Also changed the fluid in the trans and tcase. Gotta love playing with gear oil all morning.
Got the filler neck installed but still need a couple of the right size hose clamps. Even put on a new oem gas cap.
Then did some more painting.
