This thread raises an important question to the moderators and our members: Should this forum allow for sale listings for vehicles which are known to not comply with federal law?
Can you provide a URL to the ruling that replacing an engine on an imported vehicle requires that it be identical or newer?That's a slippery slope, that is. Consider that most any 25+ year old 'Cruiser with a motor swap does not comply with Federal law. Only exceptions are for "identical" and "newer, EPA approved" motors. So, not naming names (there are too many), any former 1HZ that's now a 1HD-T is in violation; any former 3B or 1PZ that's now a 1HZ is in violation; and....you get the idea. Any 3B or 1HZ with an aftermarket turbo is technically in violation of federal law. There's more. Obviously, under 25 year old cars are a red flag, though not all are here illegally, but over 25 doesn't necessarily ensure compliance, either.
I thought that non-original engine replacements were unlawful *before* importing, but were allowed once in the United States.
In the case of a 25+ year old vehicle, motor swaps are generally legal, federally and state-wise
I shouldn't have mentioned it--a lot of guys aren't going to want to hear it.
I'll find chapter and verse tonight (I'm on my way to work right now). It's in the Clean Air Act. The same rules apply "before" and "after" importing, BTW. That is, the same law that exempts 25+ year old vehicles from EPA regulations for importation, exempts them while here, but the same conditions apply.
Re: Federal law, this is not always true. Clearly true in the case of swapping in an EPA certified engine (for instance, your V8, Tony). Also clearly true in the case of replacing a motor, say a 1HZ with an "identical" motor (i.e. another 1HZ). Literal application of the law implies that it would not be true in other circumstances.
State laws are all over the place on this kind of thing.
More to follow.
BTW, the link TonyP shared only applies to EPA certified engines. Not what most of us are dealing with.
Makes me wonder how Diesel Toys in San Antonio is installing "used foreign-built" engines in Tacomas. Specifically engines like the D-4D in the Tacoma and the 1VD-FTV in the Tundra.
Here's what I think, after having imported three trucks from the Middle East: a 1992 RJ77, a 1993 Model 80 and a 1998 Model 100.
Look at the forms you actually have to fill out and sign and give to the shipping company and decide if you can, legitimately, sign it.
Here's a link to the EPA form.
In the case of the RJ77 and Model 80 I checked off Code E:
The DOT form contains the 25 year requirement (don't think about the inconsistency between EPA and DOT--that way madness lies).
I checked block 1 on the DOT form.
The 1998 turned out originally to have been sold in the US so I was able to declare it as a US vehicle. I had to prove it with a carfax report.
In sum, look at what you have to sign (or ask your seller to sign) and decide if it is truthful. I wouldn't knowingly try to import a car with an engine not identical to that it originally came with in market where it originally was sold. I just don't need the headache and worry.
Spot on. And just to clarify @John Young, your 100 series import was a US market vehicle originally. You did not import a GCC 100 series and brought it in just because 100 series were also sold in the USA. You brought in a 100 series that was originally sold in the USA, the US model of which complies with FMVSS (federal motor vehicle safety standards). That means that all of your safety equipment bears a DOT marking (e.g lights, seatbelts, hazard flasher relays...etc etc).
The above point about FMVSS is also relevant to any importation of car parts for which there is a safety standard (e.g. new 70 series headlights, seatbelts...etc). Some items, such as the actual body, I do not believe, have a FMVSS safety standard. Any part that does not bear a DOT marking or stamp is technically unlawful for importation and in turn use on American roads.
