ARCHIVE Accessory Panel Unit for the center console- need feedback (1 Viewer)
I have one left in stock. Not going to be making more for a little while. Need to catch up on other projects.
Just ordered it off your site. Can't wait to see it and get it installed!
Really liking this new organizer, great quality and it definitely clears up some space in the console!:beer:
Dangit, was just about to order one of these. Please let us know when they are back in stock...
I would be interested in one as well for my '03 LX. Would this fit underneath the upper portion of the center console like the picture posted here in this LC?
Ordered and received my Wits' End Accessory Panel Unit & Center Console Liner this week and had to install them. After all, it is Christmas, or close enough! The install was super simple. The hardest part is removing & installing the console lid. Those 4 small philips head screws were very tight. Use the supplied template to located the 4 holes to drill, use a 1/8 bit and drill through the plastic at each corner location. Screw the 4 snap screws into the holes. Snap the APU onto the snap screws and reinstall the console lid. Took all of 15 minutes. Now to finish loading it up.
Has anyone had an issue with the snaps popping loose when off road. Mine is good when used as a daily driver, but when I take it off road I find the panel loose and released from the top when I open the console up..
@NLXTACY can you chime in here?
J
There was only one instance where I saw this happen. The person had it fully loaded (not the issue) but when the holes were drilled it was off by about 1/16" and it made the snaps on one corner very tight. With the APU hanging down on the console lid, weighted downward and being pulled on one corner, it doesn't take much more to get the snap to release.
I used your template and 2-all 4 are released when wheeling. I have it somewhat loaded, but not what I'd say overloaded by any means.
J
J
On the MALE snap (the one in the lid) you can take a pair of pliers and GENTLY squeeze them to give it a slight oblong shape. This should be plenty to give it a tighter connection. Also, if you screw it up I can send out new ones :P
