I just had the head gasket done on my truck and now it is idling high. Yeah there are lots of threads on this and yes I did a search. Unfortunately none I could find could really clear up a confusing point. I have a 97 lx450. The throttle body has THREE cables coming out of it. One to the cruise control. One to the gas pedal (this is the throttle cable). And one that goes I know not where...the fsm calls this the "acclerator cable". The accelerator cable is what is causing my high idle. If I manually help it relax a bit the idle drops back to normal. I cannot just adjust it for a more loose fit..its all the way as it is. Anyone know what the accelerator cable is for and where it goes? I cant find it in the fsm and the threads here confuse throttle and accelerator when talking about these cables. I see two possibilites. One: the accelerator cable is just too tight for some reason. Two: there is a loose vacuum hose or something and the ecu is causing the accelerator cable to set too tight. Since I dont know what the accelerator cable is for or where it goes I cant make a judgement. I cannot find a loose vacuum hose either.
Ideas?
Ideas?
