Ac woes
Have you found the leak if not you can use freon to test of you don't have a way to use nitrogen to pressure test add freon it will have some pressure maybe 40 pounds or more normally with nitrogen I do 100psi then soak down every connection with spray bottle with water and 5 drops of dawn dish detergent look for bubbles
Going to try the uv dye but this is a great idea. I grew up looking for air leaks this way with a spray bottle and a dawn mixture. (Usually looking on tires though)
UPDATE: leak test completed. Uv light with glasses. I added one can of Freon and uv dye. Connections from firewall are good. Driers good. Condenser fittings aren’t leaking. The only place I saw that gives me a big concern is the compressor itself. Ok the bottom side the front seal lit up under uv. I did spray a dawn mixture on it while it was off and didn’t see any bubbles so I’m unsure if it’s actively leaking.
I filled it up with Freon to what I previously read was appropriate pressure numbers. Like 280 on the high side and 45 on the low. I’ll drive it every day and see what happens. If it leaks out again I’ll just try to source a compressor. Probably while I’m at it a condenser because that’ll stay with the car hopefully for a long time.
Anyone have a used non leaking compressor?
