Thought I might get asked that question so I'm just trying to find the page now, standby.
BTW, I am a Air Con engineer, retired (not Auto, commercial) and have been for over 40 years.
Yes, I remember you telling us that once before. Standing by.
I do beg your pardon, it's not in the FSM it's on a sticker under the hood.^^^^
I've never seen that referenced in my FSM (99 model) perhaps it exists in others. Can you cite the page and FSM where this information exists? I'm trying to imagine why it would make a difference.
Thanks
Sorry for repeating myself, I'm only trying to help, and reasure members that I do know what I'm talking about.Yes, I remember you telling us that once before. Standing by.
My 04 does exactly the same thing.I've said for years that I have found (at least on my unit) that running the rear A/C is parasitic to vent temps in the front by 5-8°F.
Also, the rear vent temps (on mine) run 10+ degrees warmer than my front vent temps. I expect this is probably normal (a disparity) owing to the different heat load back there and cabin air exchange for the rear evaporator.
But I would be interested to know how others (when actually measured) are working. I live in an especially hot and humid climate....so my A/C is taxed heavily.
I see so many replies to questions about A/C not functioning correctly, so with regard to charging refrigerant there is a set procedure regardless of auto or commercial, and one or the most overlooked parts of the recharge is the addition of oil.
The pages below are from the FSM.
My 04 100 was sold in England to the first owner I am the second owner, so it must be a European market 100 series. I don't think there will be much difference in the A/C operation or layout, you are welome to ask as many questions as you like.Interesting. So that is affixed to the insulation under your hood?
I don't find the same sticker on mine anywhere but I wonder if it is something that was added in later years?
Do have a pic of where it is located on yours, so that others with similar year models can check?
Is your vehicle (U.S. market) or other.
Sorry for all the questions.
The reason I ask is that this could be important information to know when recharging the system, though the reason for it is not readily apparent to me.
View attachment 2409300View attachment 2409301
These are the sickers I have under the bonnet and in the engine compartment, there is no evidence of any being added or removed.
Your welcome, got plenty of time now I'm retired.Thank you.
Interesting bit of information.
While I don't fully understand the reason for running the rear A/C when recharging....I will add it to my practices when doing so. It certainly can not hurt anything. If anything....give a better reflection (on the gauges at least) as to 'total heat load' and how the system is reacting to it. Not that it will change the recommended charge amount.
Appreciate your input and time.
Flint.
Did you ever get this figured out? My ac performance suffers quite a bit in the heat of the day. Way worse than my 2000 4Runner. Shopping for guages now. Any recommendations?Welp for the record I found low AC pressure today. I thought I got lucky. Are there any typical locations to look first?
Ok, got the guages and took measurements.Having a set of manifold and a way to determine the ambient temperature at the time you use them is a great start. Having the high and low side pressures and noting whether there is any 'needle flutter, etc' will greatly aid us in being able to help you.
When you have the gauges in hand let us know if you need help hooking them up or deciphering the readings.
after running for 10 minutes, full blast with windows down.
High 177
Low 19 no flutter
2k rpm
High 175
Low 10
ambient temp 90 degrees taken with instant read thermometer.
High temp went to 250Low on refrigerant is most likely scenario.
I would be inclined to add 10-12 ozs (slowly) and watch the gauges.
See if the pressure rises and settles at about 30-35 psi low side and 210-225 psi high side (possibly a bit higher).
Note if vent temps become cooler.
Low went to 35
Vent temp was 50 on highest setting
41 on medium setting.
