Abs light (1 Viewer)
JcrewLC
SoCal
Went on after installing the lift. Can’t read on scanner. What’s the possible things to check?
Pulled harness on the front lower control arms.
Check the front ABS sensors and harness.
Friend who did install said it looks good. Came on after LSPV install.
Well then ya just answered your own question--
Id be willing to bet its in the front though. Really easy to stretch that harness and pull on them.
X2 on the above responses. The wires inside the metal sleeve can get pulled apart and then cause a short. You can’t see them. check all of the sensor connections they might not be making good contact causing the abs light to come on.
There's a procedure in the FSM to validate the sensor function, very straightforward, if you don't already know how to do it.
I don’t have an fsm. I’ll try to see if someone already posted it here.
All you need are in the Resources section.
