Slomo
It's Complicated
I just finished a rebuild of my Hellfire knuckles along with the install of 5.29s. When I originally installed the knuckles, one of the ABS compatible sets, the ABS light would come on constantly and the front abs did not work. These were one of the very first sets Billy made and he was having trouble with his machine shop at the time. We decided that there was not enough material machined off and the sensor was too far from the tone ring to get a signal. The rig drove normal and the abs never kicked in once, but I never tested it on the dirt, so I put off dealing with it until the gear swap. After installing one factory knuckle and taking measurements to compare to the Hellfire knuckles, I took 3/32" off one side and 1/16 off the other. For the first 5 minutes of the initial test drive the abs light was out and all seemed well, but then it started firing off one side sporadically and cutting the brake making the truck suddenly pull hard to one side, but would kick back in within 1 second and brake normally again. When this happens I feel the normal abs sensation in the pedal and the noise associated with it. At first it only seemed to happen when I was turning but now it does it stopping straight too. It does it with hard or normal stopping and very randomly. Sensors all seemed normal and had strong magnetic pull when I had them out. Just to be sure I pulled them out and cleaned them to make sure they didn't pick up any metal and they were clean. I tested the resistance per the FSM and they were at 1.32 and 1.36 ohms respectively, well within factory spec and there was no continuity with the knuckle and sensor. I didn't find any damage to the wiring from the body connector to the sensors either.
I am stumped. Does anyone have any ideas? I am about to rip out the entire abs system because the 315s are going to be replaced by 37-40s in the not too distant future and it will be kind of pointless then anyway, but I would rather not if I don't have to.
