cruiser_guy
Out of Africa / North Africa
- Thread starter
- #21
I spoke with a body man here and he suggests that I use a panel bonding adhesive on this rather than welding. Has anyone used that stuff?
What is "waxy LPS 3". can you be more specific please?
thx
JimK
It's expensive but then there isn't a dirty weld on the backside that is going to continue to rust.
You need to POr-15 that pillar. Then form and paint a stip of metal for a gutter. Then sand the por for the glue to stick and call it repaired.
Under the gutter material (under the spot weld) I bet Toyota had bare seams. All the rust on these trucks is caused by bare seams.
Even after your done, drill a small hole that a spray oil can fit thru and flood the pillar with some sticky corrosion proofing oil.
